blt2ski wrote:
Manuals no stall outs.
New 6 so has a 4.10-1 first gear. Vs 3.1 in almighty Allison, and 2.48 in POJ4m80/th400 derivatives.
Marty
The lowest 1st gear I could find in current manual transmissions is the 6 speed Ram uses.
It has a 1 st gear ratio of 6.34. You stated the GM 6 speed auto has a 4.1. The 6l80 is actually a 4.027 first gear. Couple that with the 2 to 1 ratio of a torque converter the equalivant 8.05 ratio will out pull the Ram manual 6.34 at standstill.
Thus the manual will stall on a much smaller hill than today's automatics.
Even the Allison will do better at a 6.2 equalivant ratio as there will be no clutches to burn out in the attempt.
