Gearing...HP and torque can be manipulated via gearing...to attain
better MPG and lower RPMs cruising...
Understand this and how it works for those who must "buy'm" pre-eng,
but am hopeful it can be done on an older one... :B Should save
me a few $K's vs buying new/newer
This is where I'm going when rebuilding or updating my Suburban's
7.4L and 4L80E. +500 ft/lbs 7.4L and 1K Ft/lbs rated 4L80E
GearVendors has either 0.70 or 0.50 at around $3K. They haven't gotten
back to me on the ratios yet
7.4L will be forced fed. Not turbine, I don't like any of the potential
routing schemes to date, so belt driven gear...with an intercooler
of my design
Then the diff will go to either 4.88's or 5.54's
Gearing...so my 4 speed 4L80E will become an 8 speed with the
GearVendors electronics that will shift in/out between the 4L80E's
shift points
4L80E's gear ratios will have either a 0.7 or 0.5 gear split betwee these gear ratios
1........2.........3.........4.........R
2.48....1.48....1.00....0.75....2.07
vs the current 6L80E's gear ratios
1..........2.........3.........4.........5.........6.........R
4.027...2.364...1.532...1.152...0.852...0.667...3.064
Toss in my NP241 transfer case compound low gear ratio: 2.72 to 1
and I'll then have 16 gears, but this requires stopping and then
manually pushing the 4x4/low button
A lot of work, but since I keep them all a looooong time...going
to try and update with this portion of my vehicle
