BradW
Feb 25, 2019Explorer II
8 Gauge Wire
Got 25' of red and black 8 gauge copper wire, a 40 amp breaker and some lugs. I plan on wiring this truck correctly for the 12v frig. I hate to admit I never wired the three previous trucks correctl...
otrfun wrote:LaneW wrote:What is the max *input* current rating for your dc to dc charger? This input current rating and the length of the cable run would determine which gauge cable is most appropriate for the input. You may find this voltage drop calculator helpful. IMO, a voltage drop of <2% is ideal, but up to 3% is acceptable.
. . . I think I need to run a 4awg . . .
We ran approx. 25 ft of 2 gauge cable from the engine compartment to the input of our dc to dc charger inside our truck camper. Our dc to dc charger is rated for 40a of *output* charge current. The *input* current (i.e., alternator load) will always be higher.
The 25 ft of 2 gauge cable nets us a ~3% voltage drop at 44-45a (nominal alternator load when producing 40a of output charge current). Yes, we could have used 25 ft of 4 gauge, but that would have increased voltage drop, reduced system efficiency, resulting in a higher load on the alternator. If we had used 4 gauge, the alternator load would have increased to approx. 50-55a (or almost 60a using 6 gauge) while still producing the same 40a of output charge current. If you're interested, Ohm's Law describes all these relationships in more detail.
If you're not concerned about the load (i.e., wear and tear) on the alternator, then using a smaller cable is fine. If you are concerned about reducing the load on the alternator, then using a larger cable is the way to go. Your choice.
