ib516
Jun 24, 2018Explorer II
8 Speed Auto for HD trucks
Apparently, ZF is making an 8 Speed HD trans that can handle 1000 lb-ft. 2020 release date. I see it as the next trans in the Ram 2500 and 3500s.
LINK
LINK
Bionic Man wrote:
Or, you could just leave it in Drive, and let the automatic move through the gears exactly as it was designed to do.
MFL wrote:FishOnOne wrote:MFL wrote:
I use the lock out feature when towing heavy. I just lock out 6th, 5th is normally good, with few downshifts, unless continuing rolling hills, in which case I lock out 5th, stay in 4th. Towing heavy with same truck/FW, but with 10-speed, I'd have to lock out 10-9-8-7-6 until past hilly area, then add back 6-7-8, until headwind, lock out 8-7. Maybe most will just not use lock out, let the 10-speed continuously shift, call it good.
Not against change, or improvement, but my Ford 6-speed is a great, user friendly transmission, with spot on gear spacing.
Jerry
Jerry,
How can you comment which gears you will have to lock out when you don't know the gear ratios of the gears your referring to and you haven't towed with a 10 speed. Your assumption is the 10 speeds gear ratios 1-5 are the same as your 6 speed and I can assure you there not.
You are correct, I have no idea, but was only using the #s as an example. A new for HD 10-speed may not even have the lock out feature.
Time will tell, but my current 6-speed will be a tough act to follow, for heavy towing use.
Jerry
Jerry
Jerry,
Jerry
Jerry
Jerry,
valhalla360 wrote:Me Again wrote:
So you are saying they are now throw away trucks? A Cummins engine can go a million miles. Wonder how many transmissions that will take?
The "million mile engine" myth...sure you can keep most any engine going that long but at 15k miles per year it will take 67yrs to hit 1 million miles.
Yes, most trucks are throw away before year 30 let alone 67. No manufacturer is designing and building based on million mile assumptions.
Jerry
thomasmnile wrote:
Isn't the number of gears more about improved fuel mileage more than anything? No comparison to a truck of course but the new Camry we bought has an 8 speed slush box and it shifts......... a lot!!! All in the name of that EPA sticker that was on the window proclaiming 39/28 MPG I suppose..........
