Would anyone like to compare the Arctic Fox 811 to the Lance 855S. I know the 811 is heavier but it has larger tanks and fridge and it appears that the 811 is a little cheaper. I'll be putting it on...
If your waistline is 40" or larger, you will have trouble squeezing by the dinette table in an AF811. I still don't understand the aversion to use the slide - It takes only seconds and you do not need to deploy fully to gain easy access.
* Slide deployment dependent on waistline will likely never be found in any brochure or manual.
