Would anyone like to compare the Arctic Fox 811 to the Lance 855S. I know the 811 is heavier but it has larger tanks and fridge and it appears that the 811 is a little cheaper. I'll be putting it on...
Jim, sounds like a nice setup...all top shelf. You have the right idea to use it a bit first and see how it goes. Do be sure to weigh both axles and check that you are not overloading tires/wheels...the rest of the "upgrades" can wait. You may be all set with a 1 ton...
