Would anyone like to compare the Arctic Fox 811 to the Lance 855S. I know the 811 is heavier but it has larger tanks and fridge and it appears that the 811 is a little cheaper. I'll be putting it on...
With the 3500, you should be within your tire capacities unless you collect a lot of rocks on journeys or tow a heavy tongue weight trailer. The suspension will be up for the task, but will need something to help the sag. When addressing sag, I suggest upper StableLoad pads. If addressing sway, I suggest lower StableLoad wedges, heavier stabilizer bars or heavier dampening shocks.
