alstraub wrote:
We settled on the Lance 855S over the others after spending over a year looking. It's going on our 2012 F350SB. The overriding deciding factor was weight as they're really not all that different otherwise.
What is the loaded weight of your 855S?
Our EC 850 is ~ 3900# locked/loaded.That is with 49 gal H20, the Lance has much smaller tanks (which was another factor for us). The EC and AF have nice big tanks, a factor if you will boondock.
We found the EC and Lance to be about same on weight, AF ~ 400# heavier.Plenty of Folks run these on 3/4 ton though (look up bedlam...he is all over the place with his AF on a 3/4 ton. You should be fine with any of these on a 1 ton.
AMLRV post actual weight of each camper as it leaves the factory on a plate in the cupboard.
Good luck,
B
