burningman wrote:
... Its not really accurate to say aluminum Alcoas are fragile and troublesome.
I don' see where anyone has made that statement, but unless I missed it, this is the first time you said you were considering Alcoas. My neighbor has had two Alcoas on his Ford F250 crack at the lug holes. The only problem I have had in over nine years of use with my Aluminum Vision 19.5s is the stick on wheel weights coming off.
What tire sizes are you running on your other two one-ton duallies with aluminum Alcoas? Could you put a set on your camper truck and check for fit? How much clearence do you have on each side with your Stable Lift? How much clearence would you have with the wider tires and wheels you are considering?
