Bigfeets wrote:
Hi Bcbigfoot! After looking at your profile it does look like your battery compartment on the passenger side is different than mine. My passenger side battery compartment door is below the seam on the clam shell joint. Yours appears to land in the seam and is look bigger. Is it an aftermarket door and cubby?
Wall to Wall inside my compartment is 13 1/4". I will call it 13" and try to fit a couple of AGM's. I wish the 31's would fit!!
I checked the size of my Agm 31's, they are approx. 12 7/8" length so you maybe in luck for fitting them in your battery box.
Here is a link for info on the group 31 agm's I bought they are part #8A31DTM http://www.dekabatteries.com/assets/base/1741.pdf
