I m in the same boat
My honda manual says rated amp=13.3
rated output = 1600VA
max out put = 2000VA
amps = watts divided by volts
2000 div by 120 = 16.666
That would be for short bursts
It would start and run using those numbers , but not probably in eco mode , not probably running a converter , not probably at elevation , might be a problem with compresser head pressue at restart
I dont have a newer cub , but dont want to buy one to see if it works
Its clear to me its not going to work as older polar cubs Ive had did
If I had a popup and higher profile was a concern I would buy a new PC and a bigger gen
I dont and I own a honda 2000 so Im going with the mach 1 ps
The only reason I didnt buy one last spring was I found out Coleman was changing the compressor to one that draws .2 amps less, and I was waiting for it to come out, I`ll have one before summer
I checked around and thats the lowest amp rooftop AC made that I found
I hear some are made for semi`s but are very expensive
Ive also been keeping an eye on craigs list and have looked at recyclers
I guess theres a chance some distributer has a dusty 9201 on the shelf , I dont know if they could sell it since it has old non epa freon
I have expressed my desire to RVP Coleman that they make a low profile ,low amp Ac again. Seems like since they have compressors that draw 6.6 amps as in the mach 1 they could do it , maybe if they heard there was more intrest from tc owners
