Thanks for the post Troutguy
I asked if anyone had used a 49201a876 w/ a honda almost a year ago and its nice to hear it will run it , but for me using the gen not on eco mode as you can with 9201 is not a good thing , I have stayed in hot weather and run the AC and gen all nite in eco and the gen would spool up when the AC compressor came on , not as loud , not as much gas, nor is not being able to charge the batterys at the same time a good fit for me, spoiled I guess from the 9201
Check out the other thread "AC" Exlporer writes he just bought a camper with a newer Mach 8 cub 47201-a876
the 9201=8.5 amps at low fan 8.9 at high 1260 watts at 120F
49201A876 = 11.1 at low 11.5 at high 1450 watts at 120 F
47201A876 = 11.2 at low 11.7 at high 1550 watts at 120 F
Thats about a third more power required , no wonder it dosent preform the same , is it a good fit ? or an just the only game in town
If you want a 49201a876 you better hurry there are only the ones on the shelfs. Them its the new mach 8 cub 47201a876 with 2 motors
If you want one that preforms as a 9201 did or as close as is available
Coleman Mach 1 power saver
48207C966 = 9.3 amps at low 9.5 at high 1260 watts at 120 F
