sign_man
Nov 10, 2013Explorer
9200 ac
i'm getting alot of info saying that coleman doesnt make the polar cub (the one that draws only 8.5amp anymore, so if the "new" 9200 models draw 11.5amps and the honda eu2000i is rated for 13.3amps. a...
Reddog1 wrote:
Troutguy , I too start the AC in fan only mode, but only until I hear the fan is up to speed, then I switch to cool mode. I do run the Honda in the "eco" mode. I'm guessing that my solar keeps the battery charge high enough that I do not have to turn my charger off. Do keep in mind, my A/C is a 2004 9200.
My fridge is always on propane, unless I am on shore power, then I might switch to 120-volts. I agree, you can't run the microwave or a toaster while running the AC with the Honda 2000.
You post you don't run the Honda in "eco" mode. Have you tried to run the "eco" mode? Perhaps after your A/C is up and running on cool, you could switch to "eco" mode?
So okan-star, with your research, I understand the Coleman A/C to run today with the Honda 2000 is the Coleman Mach 1 power saver 48207C966 = 9.3 amps at low 9.5 at high 1260 watts at 120 F. or has that been replaced?
