sign_man
Nov 10, 2013Explorer
9200 ac
i'm getting alot of info saying that coleman doesnt make the polar cub (the one that draws only 8.5amp anymore, so if the "new" 9200 models draw 11.5amps and the honda eu2000i is rated for 13.3amps. a...
okan-star wrote:
Thanks for the post Troutguy
I asked if anyone had used a 49201a876 w/ a honda almost a year ago and its nice to hear it will run it , but for me using the gen not on eco mode as you can with 9201 is not a good thing , I have stayed in hot weather and run the AC and gen all nite in eco and the gen would spool up when the AC compressor came on , not as loud , not as much gas, nor is not being able to charge the batterys at the same time a good fit for me, spoiled I guess from the 9201
Check out the other thread "AC" Exlporer writes he just bought a camper with a newer Mach 8 cub 47201-a876
the 9201=8.5 amps at low fan 8.9 at high 1260 watts at 120F
49201A876 = 11.1 at low 11.5 at high 1450 watts at 120 F
47201A876 = 11.2 at low 11.7 at high 1550 watts at 120 F
Thats about a third more power required , no wonder it dosent preform the same , is it a good fit ? or an just the only game in town
If you want a 49201a876 you better hurry there are only the ones on the shelfs. Them its the new mach 8 cub 47201a876 with 2 motors
If you want one that preforms as a 9201 did or as close as is available
Coleman Mach 1 power saver
48207C966 = 9.3 amps at low 9.5 at high 1260 watts at 120 F
