Keen_Family's avatar
Keen_Family
9500lb vs 7600 lb trailer
If you have seen our other posts, we are in the process of buying a new old stock travel trailer, a 2014 Forest River Cherokee Grey Wolf 29BH. We haven't confirmed the deal yet, but we are close to signing on the dotted line.
A 2014 new old stock Forest River Cherokee 284BH has just come available, at a slightly better price, from a different dealer. The Grey wolf has a GVWR of 7753 lbs, and the 284BH has a GVWR of 9985 - so 2200 lbs heavier. Both have very similar floor plans - Queen bedroom with solid doors, living room slide, and quad bunks for the kids.
Our tow vehicle is a 2015 Ford F150, with the 3.5 ecoboost and max tow package - it is rated for 10,500 lbs. Both are under our tow capacity, but the 284BH is getting close.
We've never towed anything as heavy as either trailer. To date, the heaviest thing we've towed (on a 6000km round trip), is a 3500 lb tent trailer. We'll be getting a weight distribution hitch and sway bar combination. We expect to be doing lengthy tows (1000 - 3000 kms) with the trailer - as we will be using it as a base to explore Canada and the U.S.
What comments do you have on these trailers? Which would you be most interested?
  • camp-n-family wrote:
    With similar floor plans, I would take the lighter of the two.
    x2.
    I hope you are getting 50% off msrp on a TT that's been sitting uncared for on a dealers lot for 2 yrs. IMO, buying a 2 yr old off a dealers lot is like buying used with a warranty for appliances.
    UV damage to roof caulk, side seams and windows , tires, wheel bearings dried out, make sure the battery date is new and check propane system using a manometer.
    Not able to see : Interior wiring damage from a rodent and the carpenter ants woke up on my drive home from the dealership .
  • I tow GVWR of 7700 with the 2013 model very similar to your truck.
    It tows it very well, but not effortlessly. If I ever bought more trailer, I would upgrade trucks. It is an amazing truck, but I prefer the feeling of "not knowing its back there". I used this truck with a GVWR of 4000 pounds, and that was truly like it wasn't there. With 4000 pounds, I would get about 11.5mpg towing. With my current trailer, I struggle to get 10mpg.
    Power is not where the truck shows its weakness. Stability in a cross wind or passing trucks is my concern.
    You didn't mention the wheelbase you have? Mine is a crew cab (157"), and that will make a difference in stability.
