- madvetosExplorer
U.F.O. wrote:
I own a 97 the same as what you got. the truck weights 6600lbs on dot scales gross weight is 10000. so that gives you approx 3400 lbs. with my eagle cap 950 i am 10800 or so with my gear hope that helps.
Doesn't seem like it carries that much weight, with the weight of todays truck campers does it?
Thanks for the insight. Is that with no mods to the suspension? Thanks in advance. - FarmerjonExplorerMy 2000 F350 weighs 8500lbs and GVWR is 11,200. That's only 2700lbs, your truck can carry more.And yet without the stableloads my overloads aren't even being used yet.
- Mike_HohnsteinExplorerInteresting discussion. Worked with two F series trucks, long box extended cab, one a SRW 460 one a dually diesel. Camper 3000#, extended hitch and small cargo trailer, both trucks felt light in the front with as produced front springs. I chose to use 351 gasser springs with air bags, set alignment with camper on, tire wear OK and truck drives nice, air bags on the stock rear suspension.
44,029 PostsLatest Activity: Jan 13, 2025
