MartiniSCP
Sep 27, 2013Explorer
'99 Dutchmen Classic Fresh Water Drain?
Hello All.
We just bought this TT used.
It's in pretty good shape but there are a few niggles and I'm trying to fix them and learn the trailer.
It has a fresh water storage tank under the bed at the front of the trailer. The pump sits beside the tank.
I do not see a way to drain the tank directly without pumping it first through the gray water tank.
Am I missing something?
There is a tube from the tank that exits the bottom of the TT but I see no valve. Is that maybe a breather tube?
There is also a valve on the cold water line under the sofa between the bed and the sink and has a ring attached (like a key chain ring) and is there is a white tube below it that extends through the bottom of the TT and sticks out 2 or three inches below.
I tried turning that valve, if that's what it is, 90 degrees to the water tube and nothing happened.
There is a similar valve/tube assembly on the hot water tube under the stove.
Any idea what these valves are supposed to do?
Is there actually a valve to drain the fresh water tank without pumping it through the gray water tank first?
Thanks All.
Happy Travels.
Thanks All.
Happy Travels.
