MFL
Apr 08, 2016Nomad II
The 8,500 lbs is the dry/empty weight of that FW. It will likely be closer to 10,000 lbs loaded to camp. That wt would give you about 2,000 lbs of pin wt, plus the hitch.
It all depends on condition of your truck, the 6.0 is a strong puller. If the transmission is good, the cooling system good, etc.
I think the truck could work, but I'd probably not take it across the country.
Welcome to the forum! Maybe someone with a similar truck, will chime in with their experience, towing a FW of that size.
Jerry
Jerry
44,027 PostsLatest Activity: Mar 05, 2025
