Francesca_Knowl
May 18, 2014Explorer
Zacvv wrote:
Does anyone know what the weight should be on a trailer for it to have brakes?
LEGALLY speaking, it varies from State to State. 2,000 pounds is a common cutoff point. Also, although you don't say what you're towing it with: tow vehicle mfr's often require brakes on the trailer if over a thousand pounds.
Side note:
Is this the tandem axle trailer you mentioned in earlier posts? If so, I think it likely came OEM with brakes, and needs them.
