mkirsch wrote:
Grit dog wrote:
You got my point. OP got the runs and ran away from the thread...
Edit, sorry OP, I confused you with the guy above who posted his weights from a different setup for whatever reason.
I usually do. Don't always agree with it.
For those that question the contributor's reason for posting his weight, it is to demonstrate that these campers can come out significantly heavier than factory advertised weight.
Ultimately the OP is fine. What he is doing is something commonly done. Might need some suspension helpers to make it not look so saggy, but otherwise, load up and hit the road.
Looks like I actually missed the point, if toddb was posting to show that he's 1000lbs over what the tag on the camper says....which I was as unclear as he.
