Grit dog wrote:
Not sure what you mean by “1 wheel”. Rear axle is just like a srw once you pop the wheels off. Aside from unrelated differences like different width. Afaik, most 2500/3500/duallies if they have the same axle, they have the same brakes.
Wheel = tire and rim.
Dually has 4 tires and rims on the rear, so it seems like BFL13 seems to think there should be 4 rotors and calipers on the rear.
Also, BFL13, you don't "stomp" the brakes going down hill. You "brake firmly" which can be achieved without "stomping."
ABS should not have a thing to do with normal braking even on grades. You might activate it if you do "stomp" the pedal and it's the least bit slippery.
