BFL13 wrote:
Some confusion developing here. I am just curious how things work with trucks, but the OP wants to know if he is "safe" with his set-up. He will get weighed and then more will be known about that.
It turns out that a DRW has stronger brakes than a SRW. Eg the bigger master cylinder mentioned above. Parts manuals could give more specs for the rest of the braking systems. I did find this too:
"With four back wheels instead of two, and a stronger rear axle, a dually truck can handle a larger amount of payload weight and offer more .....Most dually trucks are also equipped with bigger, stronger brakes for additional stopping power, as well as heavy-duty shocks and springs for greater capability to tread uneven terrain and rough driving surfaces"
I still don't see why braking specs have anything to do with axle weight ratings. I see that they would make the brakes stronger if the truck is expected to carry more weight. I would think they would use the GVWR for that. Whatever, the OP has a DRW so all he wants to know is how much "margin" does he have when overweight for braking while going down a mountain.
I disagree with telling the OP he can ignore GVWR and just worry about RAWR, but nobody is going to change anybody's mind about that, so let's all just agree to disagree.
On the question of using cab weight if you go over cargo weight rating, it is strange that the same exact cargo box and frame has different CWR if the truck is Diesel or gas. The Diesel engine weighs more so the truck has less payload out of its same GVWR. But the gas version has more CWR. So there they use front end weight to add to cargo weight. Using the little bit of cab weight (750 bs eg) for some extra cargo weight does not seem so bad then. So why do they even have a CWR instead of just a total payload rating?
https://www.jdpower.com/cars/shopping-guides/what-is-a-dually-truck
Where to start...
OP will know more about what? Already know about what it weighs. I do anyway. Maybe you don't, because you aren't well informed and choose not to trust those who are.
That Ford quoted above has a larger master cyl with a dually? Great. You're applying something specific to one vehicle to form a theory about another completely different vehicle. Can say matter of factly that is not the case with all srw vs dually brake systems.
Your quote is generic clickbait garbage. Auto advice from JD Power?? LOL!
Braking spec vs axle weight rating? Can't think how to explain that on in terms you'd understand. But can say your thinking that they're not related is contradictory to what you posted above it.
YOU disagree, because YOU don't understand. Given your lack of knowledge, more listening and less theories will be to your personal benefit and grow your knowledge.
And the last paragraph you wrote.....I rest my case.
