Poppy___Nana
Jul 04, 2013Explorer
larocqup wrote:
We just bought this new TT, been out once with it and everyone really love it, much more space then our old Hybrid 19 footer. I have a couple of question about it that the seller (crap) didn't explain to me and I forgot to ask, here they are:
1. Hot water thank works with electricity and gas. Can I use both at the same time? is so, how does that work? I understand that the gas will warm the water much faster, therefore will start first when I'm taking a shower? What is the role of electricity in there? And everything related to this... Yes you can. The dual fuel source will keep the water warm/hot. Some people turn off both sources when finished with showers - however we will always leave one source on - easier to keep water warm than to heat water from a cold water source.
2. Weel bearing: I have mag with this TT, on the center of the weel, there is a chrome cap that looks like there might be a part that can be remove, I'm not sure, I don't want to break anything, is this something that can be remove so I can remove the rubber seal and grease my bearing, or I need to remove my weel to do so?Sorry I can't help with this - DH is not home to answer the ? - BUT I know our Sunline had those "chrome caps" on it and they did pop off....
3. To any one who as this type of TT, where is the electric pump? can you use it to winterize the TT? In the manual, it tells us to fill the clear water thank with antifreeze and then start the pump. There must be a way to get the pump to pump directly into the antifreeze bottle, otherwise it will take my like 5 gallons to get it done.I don't know where your water pump is located HOWEVER - if you install a winterizing kit on the pump, you will not have to "fill your fresh water tank" with anti-freeze. The kit installs on the pump and eliminates using many gallons of anti-freeze to just a few (2 maybe 3) gallons in our 34' TH. Google trailer wintrizing kit and you'll find many you-tube videos on how to install. The kit itself is relatively inexpensive!
Thanks in advance.
Happy Camping in your new TT!
44,027 PostsLatest Activity: Mar 05, 2025
