sleepy
Jun 02, 2013Explorer
To answer your numbered points:
1) the price seems reasonable to me.
2) MY generac 3600 Propane was about $3000 new in Nov 2002 (2003 1161)
they use Onans now I think... just make sure it will run your Air Cond.
3) I have a fairly large flat screen mounted on a double articulated arm to the left of the fridge on the bulkhead to the right as you look into the bed area... I drilled and bolted the mount with the nuts inside the slide-out cabinate.
4) check the skirts carefully (the lower side walls of the overhang behind the truck bed) and look at the structure under the slide room... make sure it's straight.,,, no cracks at either end. And you know about roofs and vents.
5) Contact Lance for the recepticle... it fits in front left... should be easy for you to replace the one you have.
PM me for my phone number if you need to talk as you inspect. I've done it many times before.
Sleepy
Sleepy
44,056 PostsLatest Activity: May 04, 2014
