BFL13
Apr 24, 2019Explorer II
ABS Comes and Goes Question-Update
Updated 15 May--
Hoping to get an idea from experts here what is likely happening before I give a garage an open-ended job order to find and fix it.
2003 Chev 2500HD 6.0 Gas. For the last while, the ABS lamp comes on sometimes if the back tires (not sure if just one side) go over a bump and also it happens at times during a sharp turn (mostly or always right turns) when the back end swerves. Can be at low speed in a parking lot even.
After a while with more driving (it varies how long), for no obvious reason, the lamp goes out until the next time. The bell alarm also happens as for when the ABS lamp comes on, so that works right.
I assume something is loose, but what? Thanks.
( I know the brakes still work with no ABS, so I am not worried about that )
