acritzer
May 05, 2015Explorer II
AC fan on?
Is it OK to leave the AC fan on continuously? Or, overnight...for white noise? We used to do this with our pop up, but the thermostat and AC unit were a different kind.
Old-Biscuit wrote:GaryWT wrote:
We run our fan most of the time for air flow and to keep the trailer cool if we do not need the AC. If the heat is on we do not run the fan as it would bring in cold air from the outside. We sleep with the tv on so we are not running the fan for white noise. Generally don't open the windows either.
How would it bring cold air in from outside?
RV A/C Units do not pull ANY outside air in............outside air only cools condenser (coil under slotted rear area of roof shroud)
The trailer air is pulled up thru ceiling return vent/filter across evap coil (where the air gets cold) and then out thru ducts/ceiling grill by the room fan.
Fan recirculates inside air only.....be it cool spring air/cold summer a/c air or warm winter furnace air.
