sparkydave's avatar
sparkydave
Explorer II
Aug 27, 2018
A/C gasket leaked
Fortunately, not much leaked. After a heavy rain Saturday, a slow drip came from one of the plastic screws that holds the filter screens on (Coleman Mach 3). After I got home, it appears the foam gasket has sagged, and the edges have gaps in them. New one on order.
Do these gaskets usually require regular replacement? I installed the A/C about 8 years ago, and the foam was very springy. Now whatever tension was holding the foam firmly against the roof is gone.
  • My first pup had ac, my second pup no way. I had many problems with mine freezing, bouncing, dripping, you name it.
  • Old-Biscuit wrote:
    OK....don't check the hold-down bolts
    Buy new gasket
    OK, I will.
    "After I got home, it appears the foam gasket has sagged, and the edges have gaps in them. New one on order."
  • sparkydave wrote:
    Tightening the bolts sounds like bad advice, they were tightened to compress the gasket to a specific spacing. Now that the foam has sagged, the unit is sitting too close to the roof and the bolts are loose. Sure, tightening them might help it seal again, but there's probably a good reason there's a plastic gauge to show the spacing from the roof, and the installation instructions were very specific on getting that height correct.
    I'll ask again, "Do these gaskets usually require regular replacement?".
    Buy new gasket
  • Tightening the bolts sounds like bad advice, they were tightened to compress the gasket to a specific spacing. Now that the foam has sagged, the unit is sitting too close to the roof and the bolts are loose. Sure, tightening them might help it seal again, but there's probably a good reason there's a plastic gauge to show the spacing from the roof, and the installation instructions were very specific on getting that height correct.
  • Roof Top A/C Units bounce/get jarred/vibrate from traveling down the road
    There are 4 'hold down' bolts that keep the unit up on roof
    They loosen over time and need to be tightened
    Remove ceiling grill cover and SNUG up on the 4 bolts
    SNUG (40 INCH Pounds)
    IF you over-tighten THEN you will need to replace roof gasket otherwise they last for very long time. (Mine is 12 yrs old and still doesn't leak)
    IF you over-tighten THEN you will block off the Evap Coil drip pan drain holes and condensation will leak inside RV
    IF you over-tighten you can warp RV roof causing puddles to accumulate
    SNUG ...
