TXiceman
Jul 12, 2023Explorer II
Don't over tighten the 4 bolts as this will crush the gasket. Tighten no moe than one fill turn on each.
If this does not stop the leaking, you will need to remove the a/C unit and replace the gasket. DO NOT caulk the gasket. The gasket should not be tighten more than what it takes to compress the gasket by 1/2. Tighten all 4 bolts equally.
Ken
Ken
