mich800
Apr 11, 2016Explorer
srt20 wrote:
On my wife's work truck the blend door broke off and was blocking the airflow to the vents. I removed the fan cage and reached my hand up in there and pull the door out. Took 5 mins. Works fine now, but just can't recirculate air from in the cab. Just outside air. It usually doesn't get as hot up here in WI for long periods like down south though.
Depends on the set up. On my old F150 it is simply to block off the heater core. So the more it opens up the warmer the air. When mine broke it was at full hot. So no fun in the summer. So in my case if I simply removed the blend door that would mean full heat all the time.
44,066 PostsLatest Activity: May 18, 2026
