bassenian13's avatar
bassenian13
ac qusetion
I have a duo therm rooftop ac unit that is not working. The fan kicks in, but the compressor doesn't seem to even try to kick in. I'm assuming that I am going to have to replace the unit, but is there any way to check it to see if it can be fixed?
  • Could be the start capacitor. If you have two of the same units, you could swap the capacitors out and see if it helps. If you give it a go, be sure to discharge the capacitor before removing it.
    I had the opposite problem - the blower motor would not start. A new capacitor got it going.
44,027 PostsLatest Activity: Mar 05, 2025
