bren0035
Jul 06, 2017Explorer
AC tripping in extreme heat...need suggestions!
Ok, I'm new to this forum and usually don't need to ask for this type of help as I have a good group of people that have been trailering for many years and are good at answering my questions. I'm at a loss and wanted to see if anyone on here had some ideas. Here are the details for all you trailer Dr. out there.
I just bought a used 2007 KV Sportsmen (38 ft) travel trailer. We restored the interior of the trailer and before going out camping I checked everything I could, i.e., fridge, lights, water, toilet, sink, etc. We bought this trailer to use in Havasu/Parker Dam, CA. The temps in the summer are constantly in the 110-118 range so it gets hot and stays hot all summer.
I have two AC units on my trailer. The guy I bought it from installed the second (rear) AC on its own seperate breaker and upgraded the electrical to 50amps. THE PROBLEM I HAVE IS I CAN'T SEEM TO KEEP THE MAIN AC TO STAY ON!!! The back one will stay on all day and night and blows freezing cold air, but the main one has issues running during the day, BUT will stay on at night with little issues. It trips the breaker around 11-12pm during the day and will keep tripping every time I reset it. Once it gets to be around 8-9pm at night and the sun is down, I can flip it back on and it usually stays on all night or sometimes will trip once or twice, but then will stay on all night and blow cold air.
I thought it might be pulling too many amps because it was dirty so I got up on the roof the following trip and cleaned it real good. I also replaced the breaker. Still trips! I placed a fan on the internal breaker box thinking that maybe the breaker is getting over worked and hot, but it still trips. I'm thinking it has to do with heat as it trips right when it gets extremely hot, but why would it still trip if the AC inside was still cold? Will the AC trip if the external unit get too hot? Why does the back one stay on all day and have no issue?
I've also tried turning the back one off and letting the main one work and pull amps by itself, but the same thing happens. It's hard to trouble shoot because at one point the AC will work for many hours without problem.
I've had some people say to try putting that unit on a 25-30 amp breaker and put it on the bottom of the box so there's some space in the breaker box and allows for better ventilation. I'm fearful that I could allow the AC to fry itself, but believe the idea was that the AC was trying to run harder to keep up with the hotter temperature. Again, why would the back one have NO issue at all. They are both Coleman.
Sorry for the long post, but I need to figure this out or staying out there will continue to be a huge frustration for us. The back one can't keep the trailer cool during the late afternoon.
Thoughts.
Thoughts.
