ScottG
Jan 07, 2015Nomad
If your brake lights are not on then only the controller can be bad. Without the brake lights it should never apply the brakes.
But I would have someone follow me to see if the lamps stay on when you pull away. Sometimes a mis-adjusted or failing brake lamp switch will cause the lights to stick.
