Terryallan wrote:
In 2009 it became a lawful requirement for the manufacturer to weigh each unit at the end of the line will ALL options it was to be shipped with..
Fully agree that every trailer/ motorhome - is individually weighed when it leaves the factory floor. I've seen identical units sitting on a dealer lot - with weight differences of 50-150 lbs. Just as I've seen identical cars sitting on a dealer lot with weight variances of up to 50 lbs.
Terryallan wrote:
Also. IF the dealer added anything that would increase the weight. It would be added to the totally. All this would be prominently displayed on a YELLOW sticker, on or near the door, and above the GVWR sticker on the drivers side of the unit.
A handy bit of info to have. Takes the guess work out. To know how much the unit sitting on the lot in front of you weighs as it sits.
I disagree about the weight of stuff added after it leaves the factory. Every new trailer I have weighed, and have helped friends weigh - actually weighs 200-500 lbs more than the yellow sticker when driven off the dealer lot.
I've been told by several dealers that the sticker is the weights from the factory. Dealers have to add spare tires, battery and often propane tanks. Some add vent covers and even a second AC. It depends upon the dealer and the market.
Yes, the yellow sticker gives you a good estimate of available weight.
But, I would strongly recommend that the very first think a person do after picking up any trailer is stop at the nearest certified scale and weigh the empty trailer.
Only then will you know for certain the actual weights of your trailer.
