hohenwald48 wrote:
If you know your UVW and your actual "loaded to go" weights post them here so people can get an idea of how much junk finds its way into a TT.
My UVW (yellow sticker) is 5810 and my "loaded to go" weight is right at 7800 (CAT). I travel with a full 60 gallon water tank and empty waste tanks.
Wow, you sure carry a LOT of "JUNK"! :E
Actually, there are 2 UVW ratings that should be considered - 1) the brochure listed UVW of a base trailer, the weight many erroneously quote as being the trailer's "dry weight" and 2) the actual stickered dry weight of any given trailer as it sits at the factory ready to be shipped to the dealer. In the case of my current Coachmen that first number is 3535 lbs but the second number is a whopping 280 lbs more @ 3815 lbs. We obviously travel MUCH lighter than you as our trailer's GVW loaded and ready to camp typically averages around 4500 lbs, somewhat more if I have content in any of the 3 holding tanks.
