I see what the problem is... I went on to Adco's site and it asks for your year, make and model#. When I entered that, it says you should have ordered the cover # 52243 which is 315" long by 100 " high by 96 " wide. You ordered the next one down because you just put in your length, not your make and model. You bought # 52242 and is only 291" long,(9" less) 100 " high( same) and 90" wide ( 6" less). As a result your extra wide and rather tall trailer is using up some of the height because the cover is not long enough or wide enough to give you the slack you need. I am confident that if you call and explain that you need the next size up, they will exchange for you. Hope this helps. The required info to enter is the exact trailer make and model because as I mentioned they are custom fit for different brands. Your TT is 7 ft shorter than my Bullet, BUT is 11" higher and 6" wider.
