roadrat2's avatar
roadrat2
Add a heat strip to Dometic Brisk air
We're thinking of adding a heat strip for those chilly nights that aren't cold enough to need the furnace. I know these will not 'Heat' the camper. We just want to take the chill out.
I know we will need a new thermostat.
So, is installing the heat strip an easy job...hopefully 'plug and play'? I'm guessing it goes downstream of the fan, just inside the air outlet. Also, will I need to run an extra low voltage wire to the thermostat?
Thoughts and experience from anyone who has done this will be appreciated.
  • Are the controls for your A/C unit on the A/C, or is the A/C controlled by the same T-stat that controls the propane furnace?
    If the T-stat controls the furnace and A/C, I'm not sure how the t-stat can differentiate which "heat" system to control. I haven't seen a t-stat that can control two heating systems.
