scottykrug's avatar
scottykrug
Add grease zerk to axle or not?
Just finished repacking all the hubs and noticed that there was a threaded hole at the end of the spindle and a small hole just inside the lip for the inner seal. I presume this is one of those easy lube fixtures (my axles just didn't come fully set up with that option). I will still pull them apart to service them, but is there any benefit to add the zerk to add grease? I removed the craptastic plastic grease caps (two cracked and one let water in) and replaced them with oversized old school metal ones so there will be plenty of room inside the cap. I am thinking against it, but would like to see if there is any benefit from those who have this feature.
