ScottG
May 08, 2013Nomad
Keep in mind that if you use this feature, (and I strongly suggest you don't) you have to fill the entire void inside the hub before grease will come back forward and out through the front bearing. Only when you see grease movement in the front bearing do you know both inners and outers have been lubed.
44,072 PostsLatest Activity: Aug 23, 2026
