seaeagle2
Feb 01, 2015Explorer
As far as parasitic drain, I store my trailer in the driveway plugged into shorepower so hopefully the float charger on the converter takes care of that.If we end up drycamping where it becomes an issue I can always pull the fuse. As far as fuse protection, I have a 20 amp fuse on the wire from the battery to the fuse block (in the picture it looks like a terminal block because I don't have fuses in it yet), then the hot wire to the receptacle side is fused and the hot to the USB is fused.
44,068 PostsLatest Activity: Jun 01, 2026
