LarryJM
Dec 28, 2017Explorer II
1. Never bypass the in radiator OTO cooler since that is where you get the max heat xfr and no it will never 'WARM' the oil.
2. The radiator OTO cooler will save your xxxx during slow speed or backing up/manuvering like into a camp site when the air flow over the second oil to air (OTA) is basically useless.
3. The proper routing is not a matter of opinion, but based on science and it should go thru the OTO first for #1 reason above and then to the OTA cooler.
Larry
Larry
44,071 PostsLatest Activity: Aug 30, 2026
