SidecarFlip
Dec 30, 2017Explorer III
LarryJM wrote:
WOW talk about a bunch of loose cannons and shade tree/arm chair engineers throwing that jello on the wall and hoping some of it will stick. I would highly recommend those that actually care about the truth and facts here on what the best and correct routing of the coolers is and this bunk about warming the tranny fluid by way of any of the coolers read THIS THREAD and the link there in my first or second post in that thread where I quoted the actual real authority on these tranny questions Mark Kovalsky who actually was a tranny engineer at FORD and knows what he is talking about.
Nuf Said;)
Larry
Internet 'authorities' are only as good as the article they post. I believe about 10% of what I read on the net, maybe.
Like I said, over a decade now on my truck with no issues but then I change my juice every year too. Most people ignore the slush box until it pukes then scratch their heads. Slush boxes are like crankcases, they need fresh fluid and filter changes regularly.
I ignore nothing and maintain everything. Maybe thats why my ancient 97 F350 runs like a top, gets good fuel mileage and is reliable as my wife. No rust anywhere either. I Fluid Film the underside yearly.
More popcorn... Without a doubt.
Maybe I should add that I did no modifications to the mechanicals on my 97. Ford SVO in Dearborn did everything, including the transmission cooler and radiator cooler bypass, the front and rear lockers (ARB front, Detroit True Trak in the back), the high output turbo, free air intake, total transmission rebuild with metal clutch plates and all that stuff, deep sump cast aluminum trans pan and a reprogram of the slush box (E4OD). Everything is greaseable from the upper and lower ball joints to all the universals and slip splines so all the suspension pivots, tie rod ends, drag link and pittman arm.
I did nothing but 'loan' the truck for a couple weeks to my BIL who is a design engineer at Special Vehicle Operations at Fords. You see, we are a Ford family and always have been. I'm sure they ran the bags out of it, I knew they would. They used it for a test horse in 98.
I'm just charged with maintenance and I maintain it according to the instructions I received from SVO and have for years.
Did my wife's old Ranger pickup with the V6 too. Turned it into a rocket ship. Only V6 I ever drove that in 4wd could smoke the tires on dry pavement and top 100 mph on an on ramp.
No, I don't buy into so called 'authorities' on the net. All phooey far as I'm concerned. You believe what you want to. I take credence in SVO and my BIL who is now the lead designer in the powertrain division. He was instrumental in developing the new 10 speed ford sludh box.
Keep the popcorn posts coming, I'll nuke up another bag.....:B
44,071 PostsLatest Activity: Aug 30, 2026
