danimal53's avatar
danimal53
adding 12v outlet and switch
I think I've got this all figured out, but wanted to run it by the good forum folks to see if I'm missing anything.
I want to add a 12v outlet near my radio, and a cutoff switch for the radio itself. I'm planning on installing this.
The switch will control the 12v outlet, radio, and voltmeter. The USB ports will stay powered regardless of the switch. I have full/easy access to the back of the radio, and all the wiring is clearly/neatly labelled (lucky me!). I also have the manual with wiring diagram if needed.
the radio is a Jensen jcd2010
So what I think I have to do is tap into the power going to the radio +12VDC BATTERY (memory) to power the USB (always on). Then the radio +12VDC SWITCHED (ACC) will go to my new switch, acting basically as the ignition if the radio were in a car. This will allow me to shutoff the radio so that darn superbright display won't keep me up at night, but I won't lose presets/clock.
Is it that straightforward or am I missing something? I've done a lot of house wiring/electrical, but never DC, so just double checking. I plan on using 12GA stranded wire and crimp connectors to tap into the existing wiring.
  • I think you have the wiring layout right. Ideally, I would want two switches, one to control 12V to the radio and one to control 12V to the power ports and the gauge but your circuits will work.
    Do you know how to solder? In this application, a soldered connection may be more durable than a crimped connector.
