BubbaChris
May 14, 2014Explorer
On the power cords, the lower the gauge number the bigger the actual wire inside. That allows it to either carry more load or carry the same load further in a safe manner. If you don't have enough, the cord can overheat (and more bad things can follow).
If you compare cords at a hardware store, you'll be able to see the relationship between cord gauge, amp rating, and distance.
Also going for a power cord that is outdoors-rated is important as the coating will have UV protection to help it survive in the elements.
44,069 PostsLatest Activity: Jul 05, 2026
