Houstonkid
May 14, 2014Explorer
BubbaChris wrote:
On the power cords, the lower the gauge number the bigger the actual wire inside. That allows it to either carry more load or carry the same load further in a safe manner. If you don't have enough, the cord can overheat (and more bad things can follow).
If you compare cords at a hardware store, you'll be able to see the relationship between cord gauge, amp rating, and distance.
Also going for a power cord that is outdoors-rated is important as the coating will have UV protection to help it survive in the elements.
Thanks Bubba, I knew that bout the gauge/size relation, I was just unsure if getting a smaller gauge would allow me more length to get to the pedestal.
44,069 PostsLatest Activity: Jul 05, 2026
