Pauljdav's avatar
Pauljdav
Adding 2nd air
Hi all,
I have a 2016 Dutchmen Denali 325rl.
It is 50 amp and pre wired for a 2nd ac unit.
Has anyone added a 2nd unit?
Any idea if I can tie into the ducts or if I will have to go un ducted?
Any input here is much appreciated.
Thanks,
Paul
  • I pulled the trim from the vent and it is solid braced.
    It looks like I could drill a hole towards the wiring and I am planning on putting in a non ducted unit. This is the easiest most cost effective.
    Thanks for all the replies.
    Paul
  • Anonymous's avatar
    Anonymous
    An easy way to verify would be to pull the trim ring for the vent and have a look in the cavity. If there's a duct sitting there waiting for a connection then you'd want to use a ducted AC. If not then you'd want a standalone unit. Most trailers that I've seen that come with a 2nd AC option are designed for a stand alone unit in that spot. Ducted or not, it will be effective with reducing the temps quickly.
    I would caution against trying to tie into the duct system when it's not designed for it. A lot of these trailer have a duct system designed for one AC. When you tie in a second AC then the efficiency goes down as both ACs try to force their air through the duct work.
  • C_B_'s avatar
    C_B_
    Explorer II
    Pauljdav wrote:
    Hi all,
    Thanks,
    Paul
    Had a second 15K AC added in the bedroom of my Cedar Creek 36CKTS.
    Had to mount a junction box for wiring. Tied into existing AC duct work.
    C.B.
