westend
May 02, 2018Explorer
Thai wrote:westend wrote:kerrlakeRoo wrote:
The battery you are looking at is a 65 amp hr battery, as a pair 130 total. Of which, as marine/rv batteries you can only use about 65 amps without over using them.
If you change to GC-2 batteries you would be able to use up to 75% of the 220 amps available.
I don't know what gc batteries will cost you up there but the difference in cost, and that you have to buy at least one no matter which way you go makes the upgrade to 6 volt batteries seem sensible.
X2
I'd suggest to call a golf cart distributor and see what a pair of 6V's will cost. The GC2 6V from most brands has the same footprint as BCI GRP24.
Thanks for that info. I'm going to ask if I can return the current one for a pair of Group 31's. I assume a pair of Group 31's will fit side by side in the front part of the trailer?
I dunno' what you have for a battery holder on the front of the trailer. Here's a BCI Group size Chart. As you will find, the footprint of a Grp 31 is bigger than the Grp 24.
44,066 PostsLatest Activity: Jul 25, 2018
