handye9
Apr 23, 2015Explorer II
I would carefully remove the inside wall panel. Try to not damage it beyond being reused.
Look inside the wall to check for possible electrical wiring, and check existing wall construction. Most likely, you'll need to install some framing around the new opening.
Do the framing before you cut the hole.
There are several ebay listings, for various sized doors. You'll need some putty tape and stainless screws for installing the door.
