ScottG
Apr 23, 2015Nomad
If you have vacuum or pinch bonded walls, there's no electrical or plumbing in that area. You may have aluminum framing though.
Sometimes you can see the framing outline on the outside of the RV when it's cool outside, like in the morning.
You don't want to cut the wall framing but if the area is clear then there's no reason you can't do what you want to do.
If you have wood framing then your going to have to do some investigative surgery to make sure there's nothing in the wall.
I've done the same project though and it worked out fine.
