prichardson
Jan 16, 2014Explorer
How the A/C is ducted will dictate how easy it is to add outlets. Some newer units have channels in the foam celing insulation. On those you can remove a register and probe with a tape measure and find where it runs then drill a hole for additional registers. If there are actual ducts it could be problem since you would need to run a new duct for additional registers. Opening the register on the plenum is an option; however that is usually noisy.
