handye9
Jan 16, 2014Explorer II
Some tips, if you go ahead with the vent addition.
1. Find the spot where you have clearance both inside and out. Mark your spot on interior ceiling.
2. Use a saw that has blade depth set to cut slightly less than the 1/8" ceiling panel. You don't want to cut any wires that may be laying above it. A vibrating saw works best for this. Some thing like a MultiMaster or Dremmel Multi-tool.
3. Once the inside hole is done, use a small diameter drill bit to drill up through the roof, one small hole in each corner.
4. Up on roof, use a razor knife to cut an "X" in the roof membrane, connecting the four drill holes.
5. Fold the roofing membrane out of the way and cut your hole in plywood roof.
6. Fold the membrane back into the hole (cover the edges of the plywood).
7. The vent kit will come with putty rope and screws. Apply that putty to lip of the vent and set it over the hole. Make sure your interior trim piece will line up, before you fasten the piece on the roof. When you fasten the vent, a small amout of putty should squeeze out from the screws.
8. Inside, trim and tuck the roof membrane out of the way. Install interior trim piece.
9. Go back up on roof, caulk around the vent with Dicor Lap sealant. Don't be shy with the amount.
Note: If you are going to install a Maxair vent cover, wait for caulk to dry.
